Can't open native NX 9.0 files in Creo 3.0 M060
scampbell
Anyone else having issues opening NX files? It seemed like I could open these files more successfully in F000. Could be my imagination I guess, but I testing the functionality out on 8, 8.5 and 9.0 before we made the jump.
Let me know if there is a setting on import or something stupid I am missing...
I get the"can't be retrieved message"
StephenW
(To:scampbell)
Could you upload a file we could test?
David_M
(To:scampbell)
Is the problem the filename? Don't forget Creo still needs filenames to be 31 characters or less and contain only A-Z 0-9 - and _
Steve,
As Stephen mentioned sharing a file will help us to look in this. Kindly attach a file to post (You can use "use advance editor" on right top in post for file attachment).
Just go through the below link. I hope you will find the answer.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS134024&art_lang=en&posno=1&q=which%20data%20exchange%20versio…
Manikandan
