Can we measure spring wire length of a conical helical spring
ptc-4473266
Hi Friends
I have one query that can we measure a spring wire length in pro-e. If we want to make a spring and we want to know what length of bar we required making a spring in industry then how we calculate this?
Please help on this????
If you are using a trajectory first to create the solid, you can measure the total curve length.
If the spring has a constant cross section, couldn't you simply measure the volume then divide by the cross section area to get the length?
