Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Apparently, for WF3, the ANSI standard has changed to the same as the ISO and JIS standard format for the chamfer dimensioning technique. It doesn't matter which format you select in the detail file, it will now only allow the witness line to appear and extend out the way I showed it in the picture. I can't say it's wrong, but I prefer the old method that pivots about the chamfer. Since we don't follow any standard too strictly, I would use the old method if I could. I guess I have no choice now. Thanx for the help.
