Chess piece
ptc-6778764
Chess piece
I am new to PTC, and I need to make a chess piece using the revolve tool. Anyone who could give me some guidance would be greatly appreciated!
You would create a revolve feature which requires a sketch preferably with a centerline defined within the sketch (known as a section). You would create 1/2 of the profile of the piece you want. Certain logical rules apply such as having all solid features on one side of the revolve axis (center line).
9 REPLIES 9
Dale_Rosema
(To:ptc-6778764)
First you have to choose which piece you are going to model. The knight would not be an easy revolve as say a pawn, rook, or bishop.
Im going to do the pawn, I am a very big novice to creo, would I start using the line tool?
Antonius, could you create a chess piece for me, I'm really struggling, this is my first time ever, I'll offer payment.
Are you using the full version of Creo Parametric (Creo 2.0 or 3.0)?
I Am using version 2.0, thank you!
I did a rough outline of a bishop.
Have a look at the attached file and right click on the features and select edit definition to see how they are made.
This will give you some very basic techniques.
I Cannot thank you enough sir, this is absolutely the best thing anyone has done for me in a long time, thank you so much.
My pleasure, Grant. Al the best on your project.
