I am sure this has been asked to death.
And I should know the answer to this by now.
But I'm gonna ask again.
Is there a way to get a circle centerline to show in Creo 3?
I have been using cosmetics and hiding on layers.
WayneF
Yes...IF...
If you use an AXIS pattern to create your slots AND you have the drawing setup option radial_pattern_axis_circle turned on
And I added an axis to the slot sketch
Yes...IF...
Stephen...NICE. I tried on new geometry. Works as advertised. Unfortunately I am documenting someone else's model and they used 1 feature to extrude. I don't know if I want to redo the geometry. But I will keep this in my bag of tricks. Thanks!!!
Wayne
I think you can cheat little bit ... to add the pattern of datum axis or datum points to get circle centerline.
MH
This was my first thought. It did not work. I also wanted to use Flexible Modeling. However - that is NOT available in sheet metal.![]()
I ended up redoing as patterns. Worked out nice. Thanks Stephen.
