Command search and tab keyboard shortcuts?
MGortner
Is there a keyboard shortcut to move the cursor to the command search box? Using the mouse to click in the box is very inefficient.
Another useful shortcut would be to move between tabs. I don't count using the ALT key as a shortcut since you're forced to memorize what letter to hit next or search the screen for the letter. ALT + right arrow or something like that would be very useful.
According to the online help (http://www.ptc.com/cs/help/creo_hc/creo20_hc/index.jspx?id=keyboard_mouse_shortcut&action=show) there is no keyboard shortcut. I'm sure you could create a mapkey or add it to the UI where you want it. If you have a 3D mouse you could create a mapkey and assign it to a button on the mouse. Hope this helps.
