Contour lines thickness
ptc-2027409
Hi everyone, i'd like to thicken the contour lines of my 3D parts, a little bit the same way that CATIA or Solidworks does. Is there an easy way to do that? Thank you
If I understand correctly you want to pick: View>DisplaySettings>ModelDisplay Select the Shade tab and enable the 'With Edges' option.
I agree with Matt. This, however, will apply only in the current session only. If you want to change it permanently so you don't have to repeat that every session, set the config option "show_shaded_edges" to "yes" and save your config.pro
Hi guys, well, with that trick, the edges are not thick enough. Is there a way to choose explicitly the thickness of the edges? Thank you
