Convert pro engineer wildfire to flash
ptc-2992872
hi. I was wondering if it is possible to convert the 3D files to a .fla extension (flash). The general idee is to put the files on the website, but in 3D flash. Thanks in advance. Bert
Hi Bert, are you aware that flash is still only a 2D format? It can create 3D effects, but it is not possible to convert Pro/E files into flash.
