Hello everybody,
In our company we are new to using Creo parametric. Comming from Inventor it is a pretty big adjustement.
A simple thing which I don't seem to figure out is how to convert a project line to a construction line. A normal line I can convert with holding right mouse button and selecting it. But for a projected line it isn't there.
Berry
Wecome to the forum.
there will be a horizontal "s" indicating that you have projected that line.remove that symbol, then you would be able to convert that line into construction line.
