Counter bore hole customization
bvinay
7-Bedrock
Hi everyone.
can anyone tell me how to modify a counter bore hole havong custom size.........
I wanted a CBR hole having dimensions D=0.218 deep=0.051: d=0.157 through.
In creo the option to enter 'd' value wasn't highlighted.
Please someone help me out here.
Thanks in advance.
bvinay
7-Bedrock
(To:bvinay)
TomD.inPDX
(To:bvinay)
Tapped holes are driven by hole tables which fixes the drill size for the tap.
You would create a second through hole using the normal hole rather than tapped.
You have to play a little with teh dialog. There is alot hidden under those buttons. It includes standard clearance holes for certain bolt sizes, countersinks, and other stuff.
John.Pryal
(To:bvinay)
Hi, there is a config option that may help you with hole customization, "hole_diameter_override", set to yes, allows you to edit hole diameters.
John
bvinay
7-Bedrock
(To:bvinay)
Thank you guys.
I got the way to do it.
Thank you.
