"Robert Blom" wrote:
A gear with tooth on the front in stead of on the side.
"Guinzio Mussa" wrote:
I thank you for the suggestion. But my problem is to create a face/frontal gear that gears with a pinion of which i know module and number of tooth. So the problem is to identify the 2 sections for create swept blend: they must combine with the evolvente profile of the pinion. Thanks Regards, Luciano
