Create this relation: SMT_DFLT_BEND_RADIUS = smt_thickness * 1.5
dcaucutt
7-Bedrock
Is there any way of making this relation work?
SMT_DFLT_BEND_RADIUS = SMT_THICKNESS * 1.5
If not, does anyone know why?
Why would a SMT_THICKNESS * 1.5 relation not be functional when SMT_THICKNESSSMT_THICKNESS * 2, and SMT_THICKNESS * .5 all work?
Again, if not, PTC needs to fix this so that these relations can work.
Thanks!
Hi all,
Thanks for your help. I looked into this further; I found that if I set the thickness to 1 first, and then, afterward, increase the thickness to what I need, the relation seems to be working. I'm not sure why, but this seems to be working.
Again, thanks!
4 REPLIES 4
psobejko
(To:dcaucutt)
Sorry, I'm not sure what your problem is.
I have in part relations:
SMT_DFLT_BEND_RADIUS = SMT_THICKNESS*1.5
And it works just fine (Creo 2.0 M200)...
If sheetmetal thickness is set to 1.0, then default radius available is [1.5]
If I change sheetmetal thickness to 3.1415, then radius changes to [4.71225]...
etc...
Perhaps you can provide your model where it isn't working.
Hi all,
Again, thanks!
You probably have some geometry that fails with a larger radius. Look to see if some straight length is becoming close to zero length. At least that is most typical for me.
dcokin
(To:dcaucutt)
As others have said, this relation does work just fine, and you question doesn't give us a hint as to what the nature of the failure you see is.  Getting an error message?  Or changing the multiplier just has no effect after regeneration?
There is one hint in the comments of the relations added automatically to sheet metal parts, that could be relevant:
/* The following relations make the bend allowance parameters     */
/* of part to be dependent on the assigned material, if the value */
/* of the parameter SMT_UPDATE_BEND_ALLOW_INFO is YES.  */
Perhaps you have a material applied that's overriding your change to the relations?
