Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
thanks, everyone!! It seems that to do this you need Advanced Assembly Extention (AAX) module to create simple Skeletons. My admin is installing my AAX today. thanks
