Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I am trying to create a retainer for a conical shaped membrane. Of course I could model this in the final form, but then I need to create a 2D version with relief cuts. Someone probably knows a better way?
