how to enable creation of jpeg file for the model or asm in proe wf3. Is there any preference or something specific to that ..?
Hello
(this is Basic creations of pictures - jpg/tiff Screen Snapshot)
If you need create pictures from model or asm set ProE Background: (white/black or custom color) View > Display Settings > System Colors... >> Scheme > Black on White.
Set orientation for model or asm and create Screen Snapshot: File > Save a Copy... > Select type - /JPEG (*.jpg) or TIFF (Snapshot) (*.tif)/ and set Configuration (Size, DPI etc.)
Note: if you want create nice rendered pictures >> use Render Control mode: View >> Model Setup > Render Control...
Vladimir
Thanks ...
Is there any such option to create jpeg from drawing ??
Here is quick video tutorial - How to Create jpeg from drawing in Pro/ENGINEER Wildfire 3.0
Vladimir
When I am trying to create a jpeg file its creating it of size 15 mb . What are the parameters to control the size
Configuration option for pictures quality is raster_plot_dpi (100, 200, 300 or 400) - try your custom quality for your pictures.
Vladimir
Hello Vladimir,
I am using 100 for it, which is minimum, I guess. Even then the size goes upto 14 mb.
Here is the scenario : I am using a drawing for the jpeg file creation. Jpeg file size goes upto 14 mb with 45 views in the drawing. Without any view the jpeg file size is just 4 mb. My requirement is that I want to keep the size of the jpeg constant and minimum, irrespective of the number of views. I dont care about the quality
. I asked you about the quality because I wanted to reduce it to reduce the size of the jpeg file created.
Thanks in advance ..
Regards
Awadhesh
I do not think that is possible let the original file size (jpg file) if you add new Views in your drawing - more entity=bigger size
