Creo 2.0 error 0xc6000005
ptc-5143398
Dear PTC Comumunity,
does anybody know what to do when my creo 2.0 shows error: 0xc6000005
Hopefully can somebody help me.
kind regards,
David
6 REPLIES 6
Please explain when this error presents itself.
I have the same problem. It happens just after I open Creo Parametric. I'm using Student Edition.
"Creo Parametric is shutting down because it could not run the Quality Agent, which is required in this edition. If you call Technical Support about this problem, report error 0xc6000005."
Required? Hmm.
Yes, if student wants to use Creo Parametric 2.0 Student Edition, then he has to install PTC Quality Agent along with Creo Parametric.
Martin Hanak
Martin Hanák
Hey!
So I got the same problem, I checked, the PTC Quality Agent is installed, yet it does not start when I try to start Creo Parametric 2.0.
I started the Quality Agent manually, but it still produces the same error.
PTC, any idea? Thanks in advance!
