Creo 2 M030
dgschaefer
Creo 2 M030
Does anyone (hint, hint PTC) have any info on when Creo 2 M030 is
coming?  The product calendar only says 'November 2012'.
LinkedIn
4 REPLIES 4
BenLoosli
(To:dgschaefer)
"We will release no software before it is done" or some similar quote for a specific date.
Thank you,
Ben H. Loosli
USEC, INC.
Doug
The current release date for Creo 2.0 M030 is November 30th
Paul Sagar
Director of Creo Product Management
PTC
Thanks Paul, that helps us plan.
LinkedIn
Regarding Creo 2 M030:
I will quote the PTC Tech support response to me yesterday when I opened a case for a Creo 2 M010 issue:
"M030 of Creo 2.0 will be released at 16th of november. It is recommended to use this latest build."
I replied to this, asking if this is a standard response to Creo issues now? I also explained how we have begun deploying Creo 2 across hundreds of computers: initially M010 when it was available - meantime testing M020, but we will wait for M030 now before pushing an update... Since PTC don't provide patches it's a 4GB installer each time, not great for pushing or pulling across networks to 900 people in 30 countries...
Hopefully the mass deployment TC topics make some ground, though it would require input from PTC to make things happen. Meantime, we'll probably all continue doing our own things to get the files out there.
Regards
Edwin
