Anyone have any data comparing performance or stability of Creo 2 on 32-bit vs 64-bit? We have discovered a big difference in stability on Wildfire 4.0 but I need data on Creo 2. I have searched for similar discussions here and have been unable to locate this specific discussion.
I prefer 64 bit for large assemblies because it does not limit the ram of computer which requried most in case large assemblies.
Thank you for your reply. What I really need is some hard data arround performace and stability. We do have some large assemblies so this is a consideration as well. I really try to build justification to migrate to 64-bit.
I wonder why no one has reported anything on this post...?
Michael, what have you found as to the stability/performance of Creo2 64-bit? Anyone else?
I agree that it is a valid question, but I think most people will not jump to the "known" performance loss of running 32 bit.
