Creo 3.0 Pipe command missing?
Sidhu
3-Visitor
i use Pipe command a lot. in Creo 2.0 it wasn't in a ribbon. and i added it by modifying in ribbon.
Creo 3.0, command is not there anymore. i tried searching it as well.
any Idea, where it moved to?
8 REPLIES 8
RadovanMíček
(To:Sidhu)
Try help:
1. Set the enable_obsoleted_features configuration option to yes to make the Pipe command available on the Commands Not in the Ribbon list.
2. Add the Pipe command to the desired user-defined group on the ribbon.
Software consultant.
Hi Radovan
But I try your method in the creo 3.0 m010, Pipe still can't work in my rbbon.
click Magnify Glass icon in the top right corner of Creo window. Then type pipe in text field in the top right corner of Creo window. Creo displays command names containing pipe string. Click Pipe command from displayed list.
Martin Hanak
Martin Hanák
Hi Martin
No I still don't find it .
See picture.
Martin Hanak
Martin Hanák
Creo 3.0 M010
RadovanMíček
(To:yhuang-2)
Hi
Check all your config.pro (File/Help/System Information). Check if have not 2 config.pro (usually one in Text directory and secon in Working Directory)
enable_obsoleted_features yes
Referring to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS180185, to artivate some menus, need to set enable_obsoleted_features yes
