Creo 3 help center
John.Pryal
Creo 3 help center
Hi, has anyone tried to use Creo 3 help center yet? I just loaded the files from disc, & when i try to search any topic it turns up 'no results'. Am i missing something? I can't believe i need help, to use the help center.
John
John.Pryal
(To:John.Pryal)
I think i just figured this out, i had Google Chrome set as my default browser, i set Internet Explorer as default, & it seems to work ok. The whole point of loading the files locally, was so i could access the help files without the use of the internet.
John
4 REPLIES 4
John,
you can also try web-based Help Center available at http://help.ptc.com/
Martin Hanak
Martin Hanák
John.Pryal
(To:MartinHanak)
Thank you for the reply. I will have to access the help files this way. Strange, i have always loaded the files from disc, & created a desktop shortcut to the files, never had a problem in the past.
John
John.Pryal
(To:John.Pryal)
John
Dale_Rosema
(To:John.Pryal)
When I was talking to my reseller last week, there was an option to download the help files from PTC have you looked into that?
