Creo to Solidworks
pramkumar
Creo to Solidworks
Do anyone know, in what format we need to save the creo template to open it in Solidworks???
Prabhu,
If you are working with Creo 3.0 and have license Collaboration_Ext_SolidWorks, you can Save the data as Solidworks data (.sldprt or .sldasm)
Check article at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS184567
For earlier versions you may try using global translates .iges or .step
Prabhu,
Prabhu,
Does the information in last reply answer your question?
Good day!
I am working with Creo 3.0 and have license Collaboration_Ext_SolidWorks.
When I save my Assembly unit in CreO as Solidworks.sldasm, open this file in Solid Works, so I get unit without any solid geometry, but only basic planes, like in this picture. Please, help me, how can I translate my unite from Creo to Solid Works? Thanks in advance.
StephenW
(To:okanashina)
Hi Olimpiya,
You should repost this as it's own question instead of a reply to an existing post. You will likely get much better help.
