Creo to Solidworks
  • June 29, 2015
  • 4 replies
  • 5614 views
Do anyone know, in what format we need to save the creo template to open it in Solidworks???
    Best answer by Mahesh_Sharma
    Prabhu,
    If you are working with Creo 3.0 and have license Collaboration_Ext_SolidWorks, you can Save the data as Solidworks data (.sldprt or .sldasm)
    Check article at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS184567
    For earlier versions you may try using global translates .iges or .step
    Mahesh_Sharma
    22-Sapphire I
    June 30, 2015
    Prabhu,
    Mahesh_Sharma
    22-Sapphire I
    July 1, 2015
    Prabhu,
    Does the information in last reply answer your question?
    Good day!
    I am working with Creo 3.0 and have license Collaboration_Ext_SolidWorks.
    When I save my Assembly unit in CreO as Solidworks.sldasm, open this file in Solid Works, so I get unit without any solid geometry, but only basic planes, like in this picture. Please, help me, how can I translate my unite from Creo to Solid Works? Thanks in advance.
    StephenW
    Hi Olimpiya,
    You should repost this as it's own question instead of a reply to an existing post. You will likely get much better help.
