We just migrated from WF4 to Creo2. in WF4, once we completed a dwg we alwaysused the show/erase dialog as a fast way to check if the dwg was fully dimensioned. Please tell me there is a fast way to do this in Creo...?
Does anyone know how to quickly show all dimensions (or "annotations") regardless if they were "errased", or "deleted")?
Thanks, Lawrence
Should still work the way you want it to. In Creo2 a new dialogue box shows up with a list of dimensions with boxes you "check" for the dimensions you want to show. I believe if no dimensions are unchecked then you can assume all dimensions have been shown.
