Hi All!
I am not able to install CreoPro 3.0 and help on the networked drive - i have "Not Allowed" in the status column when I specify the mapped drive (or full URL) for install path. Anybody else run into this? I have oppened a call with PTC TS, but useless so far...
I'm now having this same issue with CP3 M070. Never had this problem in the past installing to a network location. The strange thing is that I just tested again with our old M050 download and now it also throws the "Not Allowed" message. I tried the install from a couple different machines, but all were the same. I do have write privileges to the destination folder. Was a solution found for this? Thanks.
NOTE: I was not able to find a download for the attached email that David Haigh referred to, so was not able to investigate the "change a registry setting".
