Hi all,
I trying to subtract two solids in assembly but the cutout option is not highlighting, I am attaching Picture for reference, any one please help me to sort out this issue
I believe that requires the advanced assembly option (or whatever it's called these days). Do you have that?
see https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS67068
"Merge" and "Cut Out" menu entries, under "Component Operations" in Creo Parametric are available, when:
Martin Hanak
