Decals in Pro/E
brianlynn
Decals in Pro/E
Can I embed the jpeg file I am using for a decal, so when I send a component out to a manufacturer I do not need to send them the jpeg too?
[cid:image001.jpg@01CCB012.A4C14050]
The information contained in this electronic mail transmission is intended by Weil-McLain & for the use of the named individual or entity to which it is directed and may contain information that is confidential or privileged. If you have received this electronic mail transmission in error, please notify the sender of the error by reply email so that the sender's address records can be corrected and delete it from your system without copying or forwarding it, including any reply records.
RandyJones
20-Turquoise
(To:brianlynn)
checkout the config.pro option:
save_texture_with_model
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
