Decimal Places Change
AraviK1
Hi Folks,
Is ther any option to change decimal places for all dimesions in one shot?
Nope, it is set in the model configurations.
I set mine to 4 in the model and when I create a drafting dimension, it is 4 decimal placed by default.
I have this in my config.pro
default_dec_places 4
9 REPLIES 9
Nico1
(To:AraviK1)
Mark all dimensions. Then:
Layout -> Format -> Decimal Place
You can also use the Searchbar top right.
default_dec_places
value (default = 2 for non-angular dimensions)
sets the default number of decimal places (0-14) to be displayed in all model modes for non-angular dimensions. it does not affect the displayed number of digits of dimensions as modified using numdigits. the number of decimal places of dimensions created in sketcher is controlled by the option sketcher_dec_places.
config.pro options
AraviK1
(To:AraviK1)
Thanks for the reply both Nico Tonnhofer and Antonius Dirriwachter. I tried both options but its not not working for me. by the way at present i am working on WF 5.0
AraviK1
(To:AraviK1)
We can modify decimal places at one shot by using manual method.
selecting all dimensions--->
Right Click---->
Properties---->
Change Decimal places---->
OK
But i am looking for Default change "drawing options".
I hope you all clear with my doubt.
AraviK
AraviK1
(To:TomD.inPDX)
Yes Got it.
Thanks Antonius Dirriwachter.
AraviK1
(To:AraviK1)
Tools--->
Options--->
default_dec_places--->
OK
AraviK
Yep
I use 4 places by default so I can see the results of fractions or whatever reason the 4th digit accuracy is invoked. However my drawings all use 2 and 3 decimal places. It forces me to evaluate every dimension to know that they are nominally correct.
For instance, I may use 5/16 as an entry value which is .3125 and on a drawing, it should be .312 or .313. I make sure that my model and drawing are exactly the same so I edit the value in the model to be correct to the number of digits on the drawing.
I learned this when an employer that wanted to have every dimension with its own tolerance instead of relying on a title block tolerance. This forces you to think about every dimension. A bit overkill but I understand the principle.
However, these practices do force you to edit every dimension. In the grand scheme of things, it it not so bad. It really does make you be better engineer in the long run. ...and you get respect from the manufacturer that uses your model since the -drawing- is the "contractual" master to them, and they should agree 100%.
AraviK1
(To:TomD.inPDX)
Yep ,
I agree with you Antonius Dirriwachter.
AraviK
