Default name of cross section from XSEC to A B etc...?
Vermont_95
I have a question from one of my Creo Parametric user :
is it possible to change the by_default name of cross sections from XSEC001,  XSEC001 to A, B etc...?
see attached image
thanks for your help
Best regards
Veronique
1 ACCEPTED SOLUTION
unfortunatelly there is no chance to change Creo default behaviour. The name of the section has to be changed manually.
Martin Hanák
Martin Hanák
Hi Veronique,
The default name information is hard-coded into the software.  The name has to be changed manually by the users.
Amit
