Defined Cross-Section
AraviK1
Hi folks,
How to make this type of cross-section?
Can anyone help me?
AraviK
5 REPLIES 5
create offset x-section in model.
Martin Hanak
Martin Hanák
Hi
Can you list down the steps for that
Aravik
please install PTC Help and search for information in it.
Martin Hanak
Martin Hanák
Sometimes the help files are your friend The keyword is -offset- section.
It is a simple sketch and you define the section based on the sketch.
You are on WF 5 (yes?) so Creo will have a different interface.
This one is pretty straight forward with some limitations.
AraviK1
(To:TomD.inPDX)
Yes Antonius. working on WF5. will try get in help file.
AraviK
