Dimensions visualization
ftorabi
Hi All
I use Creo 2
I would like to know, if there's a way to disable the initial dimensions that apear automatically right after you create your sketch. Cause they are very annoying and I would like to create my own and only see those ones, since in some zoom scales they get mixed and make it impossible to see the sketch
1 REPLY 1
StephenW
(To:ftorabi)
No, you can not disable the creation of weak dimensions. I just ignore them. As I add strong dimensions, weak dimensions disappear. I know I have a fully constrained sketch when there are no more weak dimensions or constraints
