Creo 3.0 Parametric Showing pop up massage "Error writing file ; check disk space or write permission"
this probably means that you do not have full access rights to current working directory. Set Start in field in Creo startup shortcut to %TEMP% and try again.
MH
Vinayak,
Which datecode of Creo 3.0? AND when you are getting this error?
