Distortion of a model view in a shaded with edges mode
Vladimir_G
Hello, everyone!
I wonder why Cre misrepresents a model of a fan guard in a shaded with edges mode.
The only way to see it correctly without any distortions is to switch from the shaded with edges mode to the wireframe mode.
In the other modes Creo exchanges circles for polygons.
Thank you in advance.
Best regards, Vladimir.
file --> option --> model display --> set shade quality to: "10"
file --> option --> entity display --> edge quality display "Very High"
6 REPLIES 6
Thank you very much for your help, Aries.
That works.
Patriot_1776
(To:Vladimir_G)
Also, make sure "Small Surfaces" is checked.
Thank you, Frank.
I'll take it into account.
John.Pryal
(To:Vladimir_G)
Hi Vladimir,
if you are using Creo 1, i understand the shade quality can now be set to as high as 50.
John
Hello, John.
Yes, I'm using Creo 1.0.
But when I tried to set the shade quality as 50, Creo shut down suddenly without any warnings.
Maybe it happened because I'm using Windows XP (32 bit) as an operating system.
So it would be better for me to stop at the value 10 for the shade quality.
Regards, Vladimir.
