Does anyone know how to achieve it in Creo?
bduncan
use the following relations:
/* v ... real parameter
/* y ... real parameter
/* x1 ... string parameter
/* d0 ... name of diameter dimension
v=0
x1=extract(rel_model_name(),4,1)
y=1000
if x1=="0"
v=v+0*y
endif
if x1=="1"
v=v+1*y
endif
if x1=="2"
v=v+2*y
endif
if x1=="3"
v=v+3*y
endif
if x1=="4"
v=v+4*y
endif
if x1=="5"
v=v+5*y
endif
if x1=="6"
v=v+6*y
endif
if x1=="7"
v=v+7*y
endif
if x1=="8"
v=v+8*y
endif
if x1=="9"
v=v+9*y
endif
x1=extract(rel_model_name(),5,1)
y=100
if x1=="0"
v=v+0*y
endif
if x1=="1"
v=v+1*y
endif
if x1=="2"
v=v+2*y
endif
if x1=="3"
v=v+3*y
endif
if x1=="4"
v=v+4*y
endif
if x1=="5"
v=v+5*y
endif
if x1=="6"
v=v+6*y
endif
if x1=="7"
v=v+7*y
endif
if x1=="8"
v=v+8*y
endif
if x1=="9"
v=v+9*y
endif
x1=extract(rel_model_name(),6,1)
y=10
if x1=="0"
v=v+0*y
endif
if x1=="1"
v=v+1*y
endif
if x1=="2"
v=v+2*y
endif
if x1=="3"
v=v+3*y
endif
if x1=="4"
v=v+4*y
endif
if x1=="5"
v=v+5*y
endif
if x1=="6"
v=v+6*y
endif
if x1=="7"
v=v+7*y
endif
if x1=="8"
v=v+8*y
endif
if x1=="9"
v=v+9*y
endif
x1=extract(rel_model_name(),7,1)
y=1
if x1=="0"
v=v+0*y
endif
if x1=="1"
v=v+1*y
endif
if x1=="2"
v=v+2*y
endif
if x1=="3"
v=v+3*y
endif
if x1=="4"
v=v+4*y
endif
if x1=="5"
v=v+5*y
endif
if x1=="6"
v=v+6*y
endif
if x1=="7"
v=v+7*y
endif
if x1=="8"
v=v+8*y
endif
if x1=="9"
v=v+9*y
endif
d0=v
Rename part and regenerate it.
Martin Hanak
Martin Hanák
v=0
y=1000
if x1=="0"
v=v+0*y
endif
if x1=="1"
v=v+1*y
endif
if x1=="2"
v=v+2*y
endif
if x1=="3"
v=v+3*y
endif
if x1=="4"
v=v+4*y
endif
if x1=="5"
v=v+5*y
endif
if x1=="6"
v=v+6*y
endif
if x1=="7"
v=v+7*y
endif
if x1=="8"
v=v+8*y
endif
if x1=="9"
v=v+9*y
endif
y=100
if x1=="0"
v=v+0*y
endif
if x1=="1"
v=v+1*y
endif
if x1=="2"
v=v+2*y
endif
if x1=="3"
v=v+3*y
endif
if x1=="4"
v=v+4*y
endif
if x1=="5"
v=v+5*y
endif
if x1=="6"
v=v+6*y
endif
if x1=="7"
v=v+7*y
endif
if x1=="8"
v=v+8*y
endif
if x1=="9"
v=v+9*y
endif
y=10
if x1=="0"
v=v+0*y
endif
if x1=="1"
v=v+1*y
endif
if x1=="2"
v=v+2*y
endif
if x1=="3"
v=v+3*y
endif
if x1=="4"
v=v+4*y
endif
if x1=="5"
v=v+5*y
endif
if x1=="6"
v=v+6*y
endif
if x1=="7"
v=v+7*y
endif
if x1=="8"
v=v+8*y
endif
if x1=="9"
v=v+9*y
endif
y=1
if x1=="0"
v=v+0*y
endif
if x1=="1"
v=v+1*y
endif
if x1=="2"
v=v+2*y
endif
if x1=="3"
v=v+3*y
endif
if x1=="4"
v=v+4*y
endif
if x1=="5"
v=v+5*y
endif
if x1=="6"
v=v+6*y
endif
if x1=="7"
v=v+7*y
endif
if x1=="8"
v=v+8*y
endif
if x1=="9"
v=v+9*y
endif
d0=v
Martin Hanak
Martin Hanák
John.Pryal
(To:bduncan)
Family tables?
John
yes,recently I have made a part using family tables, I want to use part name to control the dimension.
dschenken
(To:bduncan)
You may also wish to use the string_length()function to make the relations insensitive to overall part name length.
The above assumes the filename is always 7 characters long.
It might also be more compact with the search function. search() returns a 0 if a match isn't found, so if you want to add if/endif statements to allow using this on shorter number sequences, then that's an option.
Create parameters:
digitlist, type string
value, type real
digit_found, type integer
digitlist = "0123456789"
value = 0
/* because the search function returns the number of the item in the list
/* it is necessary to subtract '1' from the result; for example '0' will be position 1,
/* but the value should be one less than that
/* the one's position is the end of the character string
digit_found = search(digitlist,extract(rel_model_name(),len(rel_model_name),1)-1
value = value+digit_found
/* the ten's position is one less than the end of the character string
digit_found = search(digitlist,extract(rel_model_name(),len(rel_model_name)-1,1)-1
value = value+digit_found*10
/* the hundred's position should be obvious by now
digit_found = search(digitlist,extract(rel_model_name(),len(rel_model_name)-2,1)-1
value = value+digit_found*100
digit_found = search(digitlist,extract(rel_model_name(),len(rel_model_name)-3,1)-1
value = value+digit_found*1000
d0=value
/*Without comments
value = 0
d0=value
David,
I'll try to remember your smart solution .
Martin Hanak
Martin Hanák
