Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hello, I am not able to edit the placement of the sketch. No dialog box opens when you select "edit" of the internal sketch, directly goes to the sketcher for editing the sketch. This happens for sketch curves also.
