Edit a mapkey
TonyRoberts
7-Bedrock
Edit a mapkey
Is there a method to edit a mapkey? I'm working on a rather long mapkey and if I miss-type a line, can I go back and change it? Tools...Mapkey...Modify seems to only let me start over from the beginning? Thanks
Hi
If your mapkey is too long why don't you try for nested mapkey ?
K.Mahanta
Tony,
if you want to change manually entered text, you can save your mapkey into config.pro file and modify mapkey by editing config.pro using notepad.
Martin Hanak
Martin Hanák
