Erase a view?
gramps
Erase a view?
OK I am having a problem trying to erase a view in Wildfire 2.0 M100
I cannot find a way to select a view and then select an "erase" command.
How do you do this now?
David Hannebohn
Seating Engineering
Ext. 4243
Workstation NAHOLLDO23997
Location 2E01
gramps
(To:gramps)
Thanks!
Got the solution. I knew I was missing something simple!
View, Drawing Display, Drawing View Visibility in the pull down
