File size in Creo 1.0 Parametric M010 & M020
BrentRMeyer
7-Bedrock
Has anyone noticed an increase in file size when moving from Wf 5.0 to Creo 1.0 Parametric M010 & M020? Some of my models have grown by a factor of 10 and has caused my PC to use up all 8Gig of RAM and files sizes of in the range of 400mb to 2 gig. Anyone have any ideas.
Well I think I found the problem. The config.pro had mutiple entries for "tol_mode nominal". I ran Creo without my config.pro and the file sizes went back to normal. I guess I had better clean up my config.pro with new versions from here on out.
