Filename search in 10.2?
davehaigh
In 9.1 you could set this preference to show the filename as search criteria on the simple search.
[cid:image001.png@01CFBC55.93D1B570]
Looked like this:
[cid:image002.png@01CFBC55.93D1B570]
I don't see anything like this in 10.2. There is no preference.
[cid:image003.png@01CFBC55.93D1B570]
I don't want to get results from the FAST indexer. I just want the matching filename.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
In 10.2, you have to click on the Advanced Search tab and if you select CAD
Document as your type, it is an option under Criteria. You can then save
the search or use it again from the Search History menu before it drops off.
David
Make sure select only [Types] that have filenames.
[cid:image001.jpg@01CFBCA8.6EA18340]
After this you can select [Filename] from Criteria.
[cid:image006.png@01CFBCA8.6E90E170]
Corey L. Jones
Design Engineering Systems Specialist
Principal Engineering Technology Development Group
ESC - Team QNA
SGT Inc.
Kennedy Space Center, FL 32899
NOTICE . . . The information contained in this communication may be sensitive, proprietary, legally privileged and/or subject to U.S. export control laws, is intended only for the use of the recipient named above. You agree to comply strictly with all U.S. export laws and assume sole responsibility for obtaining licenses to export or re-export as may be required. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication, or any of its contents, is strictly prohibited. If you have received this communication in error, please re-send this communication to the sender and delete the original message and any copy of it.
