Flatten Form
wfalco
Flatten Form
Is there a re-form/bend back after flatten form?
wfalco
(To:wfalco)
No takers?
wfalco
(To:wfalco)
Let me clarify:
Normally you un flatten and create a feature, then bend back.
I want to do the same with a form feature.
I can flatten a form....like unbending - in a sense.
I would like to create a feature on the flat.....then form back (like
bend back) ....but I don't see it.
Flatten form is under shapes as bend back is under bend commands.
KrisR
(To:wfalco)
Is it something that you can do in sheet metal? Use the flatten tool then suppress the "flatten"?
