GENERAL_UNDO_STACK_LIMIT
dgschaefer
We're now installing WF 2.  I'm going through and removing invalid entries from our corporate configs and looking for new ones that we might want to set globally.  I have a question for you (first of several, I bet):
Is there a downside to setting GENERAL_UNDO_STACK_LIMIT to a higher value than the default of 50?  I'm thinking like 250 or so, but will this have a significant negative impact on system resources, speed, etc?  I assume no, but you know how that goes.  🙂
Doug Schaefer
LinkedIn
0 REPLIES 0
