Help with assembling an internal spur gear
ptc-4696384
I am trying to setup an internal spur gear where the inner (smaller) gear is fixed and the outer (larger) gear revolves around. While I can constrain the motion of the 2 gears by fixing the appropriate DOFs, this is not compatible with the gear tool. I've tried to use the cylinder and other joint connections without success. Any suggestions?
1 REPLY 1
You might try treating like a belt.
