I am trying to setup an internal spur gear where the inner (smaller) gear is fixed and the outer (larger) gear revolves around. While I can constrain the motion of the 2 gears by fixing the appropriate DOFs, this is not compatible with the gear tool. I've tried to use the cylinder and other joint connections without success. Any suggestions?
You might try treating like a belt.
