Help with curve and meaning of symbol in parametric
bbrannerud
Hello i need help with an easy task. I should do an curve witch i think exist of three arcs, but it should be done Exactly like in the first Picture(same symbols, same numbers and so on). As u can see, ON the two arcs in the first picture it is an symbol witch looks like a spline, what does it mean and how should I proced to make this like they do in the first pic?
First Picture:
http://imgur.com/rLLMPFr,N9hk6Ty
Second Picture (where I am)
http://imgur.com/rLLMPFr,N9hk6Ty#1
Bjorn,
reference geometry can be selected from the same part or from another one in context of assembly. See picture.
Martin Hanak
Martin Hanák
6 REPLIES 6
你好,我不知道。我也想学习Creo 2.0
That is a projected curve from an external source.
Bjorn,
Martin Hanak
Martin Hanák
Okey, but there is not any curve that I can Project there?
There were... maybe hidden?
In a sketch, projected curves can be trimmed or extended.
The seed curve could be smaller.
Bjorn,
can you upload your model ? See How to attach file when you Reply to a discussion.
Martin Hanak
Martin Hanák
