How are people creating gears (true gears) in Creo?
Preferably a free way, and not a purchased package.
thanks!
1) What kind of gears - straight spur, helical, bevel, worm, crown, rack, hypoid, et al?
2) What purpose - drive CNC, drive Simulation, Look Good?
Oh great questions. spur gears and racks. And they will be functional parts from injection molded plastic.
Hears a good discussion about planetary gears:
http://communities.ptc.com/message/229781#229781
and in there, Antonius has a discussion about mechanism and gears:
http://communities.ptc.com/message/226058#226058
Thanks, Dale
Thanks for the info, but I want to model the involutes. I'm not going to use it with mechanism.
You can either create the teeth using datum curves driven by equations, which is pretty easy, or try using Inkscape which has an involute spur gear creator and export the profile from there.
If you haven't done any work with involute gears before, there are some videos on YouTube from the Fellows Gear Company that are short and highly informative.
The trickier part is if you are creating gears that have few teeth or some other special case. If so, then consider looking to hire a consulting firm that has some experience in gear and plastics. It's a common enough problem that there are some good choices. There are an infinite number of ways to tweak the design of the teeth and there's not enough time for me to type them all out.
