How can I migrate fonts to PTC CREO Parametric 3.0?
jtijerinagarza
Is there a way to migrate some fonts fonts from CATIA to CREO like SSS1, SSS2... or any others? How can I do that?
3 REPLIES 3
Creo recognizes PTC internal fonts and TTF fonts. If Catia uses TTF fonts and you know their location then you can copy their files into Creo installation.
MH
Martin Hanák
Can you show me how to do that? maybe some visual aid please?
in Creo TTF fonts are located  in CR3_LOADPOINT\Common Files\Mxxx\text\fonts directory. You can also place additional fonts into some specific directory and use config.pro option PRO_FONT_DIR.
I do not know where fonts are located in CATIA.
MH
Martin Hanák
