I modelled a shape using free style tool. But I am not able to put a standard hole in the model. How do I do it?
Welcome to the forum.
You cannot add holes to surface models. You can do one of two things:
1) Solidify the freestyle model and you can then add holes
2) Extrude a cylindrical surface that intersects the model and Merge the two surfaces.
