You know, it's an "engraved text on a cylinder"
FROM A WRAP That should be obvious since a simple "project" doesn't work properly on a cylinder.
The knowledge base has led me to a ridiculously complicated routine involving projecting and selecting in an absurdly complicated process.
I really should add that it doesn't work either.
Is this really the best we can do at this point?
Thanks Toby.
I actually succeeded yesterday by using an offset WITH DRAFT.
The offset used an internal section with the wrapped text as projected loops.
Moving this to the Creo Modeling space to give it the right exposure.
Thanks Toby.
You are most welcome Vince.
Since you found the answer, would you please mark your own answer as correct add to this discussion with any relevant details?
This way others who are reading know the question was answered and what the solution is.
Best,
Toby
I should add that this only works if the wrap is less than 180°
All information is helpful 🙂
