Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Sorry if you got this twice. I hit the send button before I finished. I can't seem to remember how to delete a symmetry line. I thought there used to be a way. Any help would be great.
As I learned through this venue - select the Delete icon, pick the symmetry lines and Done Sel. We should be able to select them and right mouse button to get the Delete option, but we can only erase them that way.
Andy Dvorak
