How to create teeth on the curved surfaces of cylinder
svaidya
3-Newcomer
Hi I want to create teeth on the curved surfaces. I tried projecting the teeth sketch on the curve it's showing error.
Here by I am attaching my model file for reference. Please help me out to resolve this.
8 REPLIES 8
upload your model using How to attach file when you Reply to a discussion.
MH
Martin Hanák
please upload your Creo part, not PDF ! And attach it to this discussion !
MH
Martin Hanák
Make the tooth-ridge solid and extrude/cut a single V.  Then pattern the V cut.
Is this a functional gear or simply a tooth pattern?  What is the purpose of the model?  The what is the purpose of the part?  etc...
dschenken
(To:svaidya)
Look for the wrap option (not warp). Create a cylinder surface and then wrap a datum curve that is the shape of the teeth onto it. Then create a variable section sweep driven by the edge of the cylinder and referencing the wrapped curve. Not going to guarantee it works; but that's what I would try.
...a few VSS options:
Hi Antonius,
Could you please attach Creo file for the same.
It's Creo 3 commercial version...
BHOoi
(To:svaidya)
Non swept version in Creo 2
