How to cut an angle onto tubing?
sgtlethargic
I'm trying to cut an angle onto roll bar tubing, but I'm not finding anything the works. Thanks, Kurt
8 REPLIES 8
Now I've got a workplane set up at an angle. What function can I use to remove the material from between the two workplanes? Thanks, Kurt
Let's see if this picture will post:
Nope, how bout a link?: http://i164.photobucket.com/albums/u31/sgtlethargic/CoCreate%20CAD/tubingslicescreenshot.jpg
Link worked, HTML?: <a href=""http://s164.photobucket.com/albums/u31/sgtlethargic/CoCreate%20CAD/?action=view&current=tubingslicescreenshot.jpg"" target=""_blank""><img src=""http://i164.photobucket.com/albums/u31/sgtlethargic/CoCreate%20CAD/tubingslicescreenshot.jpg"" border=""0"" alt=""Photobucket""></a>
PS- Is there an attachment function for this forum?
Not applicable
(To:sgtlethargic)
anonymous wrote:
sgtlethargic - 2009-03-04 9:42 PM PS- Is there an attachment function for this forum?
Not applicable
(To:)
Here is one option. Create a new workplane using the ""on axis"" function. Build a closed profile on this workplane that includes the angled line that would enclose the portion of the existing tube to be removed. Use the punch function to cut away the angle.
ptc-1796973
(To:)
Another option is to use a workplane on axis like Mike said, but then just move the face using the ""rotate"" option. When doing this, select the W axis of the workplane to rotate around.
